Jul 17th, 2024, 3:38am
Detecting "end of simulation" (Read 2530 times)
nthoangga
Oct 07th, 2016, 3:50pm
I have a block of code that monitor a signal in VerilogAMS. Right now, I'm trying to do $fdisplay to output the maximum value of that signal, but I only want to output it once for the whole simulation.
So the question is: "Is there anyway to detect end of simulation, so that I can trigger the $fdisplay event at end of simulation?"
Right now, I have a quick hack of triggering $fdisplay at arSimTime, and I specify arSimTime on my ADE state. But this won't work if I kill my simulation or my simulation crash in the middle.
Hoang
kemiyun
Re: Detecting "end of simulation"
Reply #1 - Oct 7th, 2016, 10:29pm
To get rid of time parameter in ADE you can do
@(final_step)
   $fdisplay
I haven't checked if final_step event occurs if the sim is killed or crashed graciously but it is very likely that it does.
Checking an unexpected crash (power outage or something) is very hard I think. Easiest way I can think of is opening a file and updating the value you want to report whenever it is changed.
nthoangga
Reply #2 - Oct 14th, 2016, 8:07am
Thanks for your reply. "final_step" does work when the sim runs untill finished.
Because I have to submit the sim through lsf, "final_step" doesn't catch it when I kill the sim (which is equivalent to power outage?).
I haven't try to stop the sim through ADE and see if "final_step" will work in that case though.
