Aug 16th, 2024, 11:46am
Filter to be used in PSS and Pnoise (Read 1269 times)
WishToRemainAnonymous
Santa Clara, CA, USA
Oct 14th, 2016, 10:17am
Hello All,
I have a filter that I need to use in PSS + PAC and PSS + Pnoise simulations. I checked that it works fine in PSS and PAC simulations. I have two questions in this regard.
1. I wanted to know from you if there are any issues using the Laplace function for this filter as many sources suggest avoiding the use of Laplace function.
2. I wish to have an initial condition to the output of this filter that is not 0. Is there a way to add that to the code? Please let me know.
// VerilogA for zz_aarakali, filter_with_a_notch, veriloga
`include "constants.vams"
`include "disciplines.vams"
module filter_with_a_notch(in,out);
input in;
output out;
voltage in,out;
parameter f_notch=480e6;
parameter f_lpf=200e6;
real wz,wp;
real n[0:2],d[0:3];
analog begin
wz=2*`M_PI*f_notch;
wp=2*`M_PI*f_lpf;
n[0]=1;
n[1]=0;
n[2]=1/wz/wz;
d[0]=1;
d[1]=2/wp;
d[2]=2/wp/wp;
d[3]=1/wp/wp/wp;
V(out) <+ laplace_nd(V(in),n,d);
endmodul
Re: Filter to be used in PSS and Pnoise
Reply #1 - Oct 14th, 2016, 11:41am
I know of no issue with the laplace filters.
The transient analysis starts with a DC analysis to set the initial condition. There is no support for explicitly setting the initial condition on the laplace filter itself. If you need it to start from zero, then you should probably skip the DC analysis entirely.
Reply #2 - Oct 14th, 2016, 11:47am
Thanks Ken for the information! There are no known issues using "Laplace" function in a block that is to be used in PSS + Pnoise simulations right? Please let me know.
Reply #3 - Oct 14th, 2016, 7:47pm
