Jul 21st, 2024, 3:20am
spectre pss analysis convergence failure (Read 3962 times)
simsim
Oct 24th, 2016, 8:13pm
I have a two stage amplifier chain, and I am trying to run pac analysis on it. However, the pss analysis is failing to converge. Here is some messages from spectre. What could be done to make this pss analysis converge?
Important parameter values in pss iteration:
   start = 103.3 us
   outputstart = 83.3 us
   stop = 106.633 us
   period = 3.33333 us
   maxperiods = 60
   steadyratio = 1e-03
   step = 23.3333 ns
   maxstep = 50 ns
   ic = node
   useprevic = no
   skipdc = yes
   reltol = 1e-03
   abstol(V) = 1 uV
   abstol(I) = 1 pA
   temp = 27 C
   tnom = 27 C
   tempeffects = all
   errpreset = liberal
   method = gear2only
   lteratio = 3.5
   relref = sigglobal
   cmin = 5 fF
   gmin = 0 S
   rabsshort = 1 mOhm
Warning from spectre at time = 103.317 us during periodic steady state analysis `pss'.
   WARNING (SPECTRE-16941): Floating point exception encountered in device loading. This might result in convergence problems during simulation. Check the device model equations for any illegal operations, such as divide by 0 or data overflow.
Warning from spectre at time = 103.304 us during periodic steady state analysis `pss'.
Warning from spectre at time = 103.301 us during periodic steady state analysis `pss'.
Warning from spectre at time = 103.3 us during periodic steady state analysis `pss'.
       Further occurrences of this warning will be suppressed.
Error found by spectre at time = 103.333 us during periodic steady state analysis `pss'.
   ERROR (SPECTRE-16192): No convergence achieved with the minimum time step specified.
Warning from spectre at time = 103.333 us during periodic steady state analysis `pss'.
   WARNING (SPECTRE-223): Detected NaN at node AGND.
   WARNING (SPECTRE-223): Detected NaN at node OUTM_INT.
   WARNING (SPECTRE-223): Detected NaN at node OUTP_INT.
   WARNING (SPECTRE-223): Detected NaN at node VREF_OCM_INT.
   WARNING (SPECTRE-223): Detected NaN at node I0.I1.net065.
The values for those nodes that did not converge on the last Newton iteration are given below.  The manner in which the convergence criteria were not satisfied is also given.
           Failed test: | Value | > RelTol*Ref + AbsTol
Top 10 Residue too large Convergence failure:
   V(I0.I0.M74:int_g) = 381.725 mV, previously 381.725 mV.
       residue too large: | 9.50548e+18 A | > 9.50548e+15 A + 1 pA
   V(I0.I0.M79:int_g) = 381.725 mV, previously 381.725 mV.
       residue too large: | 10.1416e+18 A | > 10.1416e+15 A + 1 pA
   V(I0.I0.M77:int_g) = 381.725 mV, previously 381.725 mV.
       residue too large: | 2.5354e+18 A | > 2.5354e+15 A + 1 pA
   V(I0.I1.I83.M1:int_g) = 1.1875 mV, previously 1.1875 mV.
       residue too large: | 2.28539e+18 A | > 2.28539e+15 A + 1 pA
   V(I0.I1.I78.M1:int_g) = 996.209 mV, previously 996.209 mV.
       residue too large: | 265.561 GA | > 265.561 MA + 1 pA
   V(I0.I1.I79.M1:int_g) = 1.00899 V, previously 1.00899 V.
       residue too large: | 254.54e+18 A | > 254.54e+15 A + 1 pA
   V(I0.I1.I84.M1:int_g) = -6.5685 mV, previously -6.5685 mV.
       residue too large: | -784.669e+15 A | > 784.669 TA + 1 pA
   V(I0.MPCSC_INT_IDAC2:int_g) = 530.756 mV, previously 530.756 mV.
       residue too large: | 4.80519e+15 A | > 4.80519 TA + 1 pA
   V(I0.I5.M2:int_g) = 254.18 pV, previously 254.179 pV.
       residue too large: | 845.724 TA | > 845.724 GA + 1 pA
   V(I0.I4.M2:int_g) = 199.721 pV, previously 199.721 pV.
       residue too large: | 911.165 TA | > 911.165 GA + 1 pA
Mohit
Re: spectre pss analysis convergence failure
Reply #1 - Oct 25th, 2016, 2:56am
Did you read the warning messages?
Reply #2 - Oct 26th, 2016, 8:07am
Is there anything a user can do to diagnose this warning?
Is the user supposed to dig out the device model equations?
I am curious what device models are used in this simulation.  simsim, can you tell us the circuit inventory?
Reply #3 - Oct 26th, 2016, 3:59pm
He has given us very little to go on, so it is hard to give any useful advice. However, when I saw the warning messages I though 'there is a poorly written Verilog-A model that is throwing a floating point exception. I wondered if that possibility had been explored.
