Jul 22nd, 2024, 5:26pm
Is there HSPICE function that rounds a parameter's value to the nearest integer? (Read 879 times)
AA
Nov 18th, 2016, 9:18am
I know there is an HSPICE function int(x) that returns the integer part of parameter x.
But, is there a similar function that rounds a parameter value to the nearest integer? For example, if the param value is 1.9, the function should return 2.
Thank you.
AA
Re: Is there HSPICE function that rounds a parameter's value to the nearest integer?
Reply #1 - Nov 18th, 2016, 9:49am
I've just realized that this can be done using the same int() function.
To round x to the nearest integer (assuming x is positive), we use int(x+0.5).
I hope someone will find this useful in the future.
Reply #2 - Nov 21st, 2016, 12:11pm
Some simulator I was using recently has "nint" for nearest integer.
