Dec 29th, 2025, 11:55am
Creation of Smith Chart by OCEAN in Cadence ViVA (Read 1821 times)
cheap_salary
Dec 12th, 2016, 4:53am
I can easily create Smith Chart by OCEAN for Cadence Wavescan and Cadence AWD.
However I can not create Smith Chart by OCEAN for Cadence ViVA.
The followings are both uneffective in Cadence ViVA.
displayMode("smith")
awvSetSmithModeType( window(2) "impedance" ?subwindow 3 )
How to create Smith Chart by OCEAN in Cadence ViVA ?
cheap_salary
Re: Creation of Smith Chart by OCEAN in Cadence ViVA
Reply #1 - Dec 13th, 2016, 4:57am
Self-follow-up.
I can create Imedance Chart by using following code in Cadence ViVA.
wid = newWindow()
awvSetSmithModeType(wid, "impedance", ?subwindow 1)
If you prefer admittance chart, use following.
wid = newWindow()
awvSetSmithModeType(wid, "admittance", ?subwindow 1)
We have to use both displayMode() and awvSetSmithModeType() in this order for Cadence ViVA.
This procedure is different from Cadence Wavescan and Cadence AWD.
Reply #2 - Dec 29th, 2016, 6:14am
You also can use the public (but not properly documented, for some reason) smithType("impedance") function which is more OCEAN-like.
I've requested that it is properly documented.
Note that the procedure is slightly different with the Qt-based ViVA in IC615 onwards because the new implementation doesn't support a window being able to morph from a rectangular to a circular window type - you have to create the window the way you want it up front, rather than changing it later.
cheap_salary
Reply #3 - Jan 11th, 2017, 4:39am
Andrew Beckett wrote on Dec 29th, 2016, 6:14am:
This can work as sams as "awvSetSmithModeType(wid, "impedance", ?subwindow 1)".
There is no cool method to create new smith chart by Skill Codes.
So I have to invoke either code of the followings.
wid = newWindow()
wid = newWindow()
Reply #4 - Jan 11th, 2017, 6:55am
You could just do this:
procedure(MySmithChart(@optional (type "impedance"))
  prog1( ; this returns the return value of the first argument
    newWindow()
    smithType(type)
Then you can do:
wid1=MySmithChart()
wid2=MySmithChart("admittance")
The benefit of a programming language is that you can write functions to make things simpler (and cooler, to use your phrase).
cheap_salary
Reply #5 - Jan 11th, 2017, 7:46am
Actually my code is a part of large procedure.
Anyway skill functions are incomplete for Smith Chart.
For example, I can not place marker on Smith Chart by Skill.
Reply #6 - Jan 11th, 2017, 8:03am
You should contact http://support.cadence.com and request that as an enhancement.
