Jul 21st, 2024, 3:25pm
How to set Font Style of Cadence ViVA (Read 3224 times)
cheap_salary
Feb 20th, 2017, 5:49am
I would like to set default font(font_name, size, font_style) by using Skill Language.
Currently I set these except for font_style by using following.
Font_Name="Roboto Mono Medium"
Font_Size=10
my_font2 = "Roboto Mono Medium,10,-1,5,50,0,0,0,0,0"
envSetVal("viva.axis" "font" 'string my_font2)
However I can not set Font_Style as "Bold".
How to set Font style, e.g. Italic, Normal, Bold Italic and Bold.
And I don't know meaning of "-1,5,50,0,0,0,0,0".
What do these number mean ?
I know second and third zeros are for "Effects/Underline" and "Effects/Strikeout"
I use IC6.1.7-64b.500.5.
« Last Edit: Feb 20th, 2017, 8:07am by cheap_salary »
Re: How to set Font Style of Cadence ViVA
Reply #1 - Feb 20th, 2017, 7:22am
That reminds me of the options in the old "xfontsel" utility:
-fnddry-fmly-wght-slant-sWdth-adstyl-pxlsz-ptSz-resx-resy-spc-avgWdth-rgstry-enc
dng
for example,
-b&h-lucida-medium-r-normal-sans-10-100-75-75-p-58-is08859-1
cheap_salary
Reply #2 - Feb 20th, 2017, 7:41am
Geoffrey_Coram wrote on Feb 20th, 2017, 7:22am:
dng
for example,
Unnh.
Logical Font Description does not match.
By the way, until IC6.1.6, Bitmap Fons are used.
However since IC6.1.7, TrueType Fonts are used.
cheap_salary
Reply #3 - Feb 20th, 2017, 7:54am
I can find out hint.
https://community.cadence.com/cadence_technology_forums/f/38/t/30504
For these variables, the font string is
<Font family>, <Point size>, <Pixel size>, <Style hint>, <Weight>, <Style>, <Underline>, <Strikeout>, <Fixed pitch>, <Raw mode>
However still I can not set font style as Bold.
I can set Normal or Italic.
Of course, I can set it as Bold from GUI.
Reply #4 - Feb 21st, 2017, 7:16am
Using 100 for the weight looks bold to me:
my_font2 = "Roboto Mono Medium,10,-1,5,100,0,0,0,0,0"
(I can definitely see a difference between 50 and 100, when I plot the same waveform in two windows and switch back and forth between them.)
