Skamlesh,
Use the standard setup for data converters. fclk = 10MHz fin = (105/2^20)*10MHz ~1001Hz Tstop = (2^20 + a few cycles)/10MHz
Use the cosine^2 window for the FFT.
Since you have an ADC, strobing is not required. The benefit is primarily reducing the amount of data saved.
The attached plot shows an extreme example, it is a four stage cascade, multi-bit ADC.
