Sep 22nd, 2026, 1:29pm
Export effective cds.lib contents (Read 4088 times)
pupule
Jul 21st, 2017, 8:28am
I have a cds.lib that is created by a few files with a number of environment variables set by project setup files.  Is there a way to export an effective cds.lib file with all of the environment variables elaborated?
Pupule
Re: Export effective cds.lib contents
Reply #1 - Jul 25th, 2017, 12:08pm
I don't think there's a direct utility to do it, but with a small bit of SKILL code this is easy enough:
procedure(DGexportCdsLib(newCdsLibPath)
  let((outp)
    outp=outfile(newCdsLibPath)
    unless(outp error("Could not write to %L\n" newCdsLibPath))
    foreach(lib ddGetLibList()
	fprintf(outp "DEFINE %s %s\n" lib~>name lib~>readPath)
    close(outp)
Then just use DGexportCdsLib("./export.lib")
