Jul 16th, 2024, 1:48am
Zero diagonal found in Jacobian error while running SCCMFB circuit simulation (Read 2471 times)
heavn007
Aug 02nd, 2017, 4:45am
Hello everyone,
I am trying to implement sccmfb based fully differential opamp for Delta Sigma Modulator. I am using two non overlapping clock signals (clk1 and clk2, clk1 is for sensing phase and clk2 for charge sharing phase). I want to know DC gain, bandwidth, loop gain of this circuit, so I am trying to run PSS + PAC and PSS+PSTB analysis.
While, I run the PSS analysis with following setup configuration:
Beat frequency : 20
No. of Harminis : 0
Accuracy : moderate
tstab: 40u
Below errors are coming in output log.
Zero diagonal found in Jacobian at `I6.net17' and `I6.net17'.
Zero diagonal found in Jacobian at `I6.net22' and `I6.net22'.
WARNING (SPECTRE-16266): Error requirements were not satisfied because of convergence difficulties.
Also, I am not getting any result from direct plot form.
In short, I want to know how can I measure dc gain, bandwidth, loopgain of SCCMFB based fully differential opamp. My clock frequency is 50kHz and signal bandwidth is 50Hz.
Re: Zero diagonal found in Jacobian error while running SCCMFB circuit simulation
Reply #1 - Aug 2nd, 2017, 5:25am
From the picture, and your statement that you have non-overlapping clocks, it's clear that, when both phi1 and phi2 are low, you have capacitor C2 and the two nets it is connected to (net17 and the unlabeled node on the other side of C2) just hanging out in complete isolation. The same problem happens with net22 and C5.
heavn007
Reply #2 - Aug 2nd, 2017, 11:54pm
Hi Geoffrey_Coram,
Thank you for replying. I need to use non overlapping clock (NOC) for my design. Is there anyway I can remove the warning without modifying NOC and run PSS+PAC for analysis successfully. I would be grateful if you provide me any useful links regarding this matter.
I am attaching my test bench schematic.
Reply #3 - Aug 3rd, 2017, 12:54pm
Can you put a very large resistor from net17 to ground (and another from net22 to ground)?
Reply #4 - Aug 5th, 2017, 1:57am
Although there should be a gmin resistor inserted by the simulator from there to ground anyway (I believe).
The snippet of the log file you sent doesn't sound severe enough to cause PSS to fail - and even if it did, there would be something else which might give more detail. Can you please post the whole spectre.out file?
Reply #5 - Aug 7th, 2017, 6:07am
Interesting points, Andrew!
Andrew Beckett wrote on Aug 5th, 2017, 1:57am:
Would that gmin be inserted, even if it wasn't needed at time=0? Suppose the switch is closed for the dc/time=0 solution, providing a dc path, but later opens up. Would Spectre know to insert a gmin?
Interesting point! The original post included only warnings: Quote:
Reply #6 - Aug 7th, 2017, 10:15am
Geoffrey_Coram wrote on Aug 7th, 2017, 6:07am:
Good point. I don't think it would.
pdirac
Reply #7 - Aug 7th, 2019, 3:13am
Actually as Geoffrey_Coram stated the capacitors C2 and C5 are floating during the time clocks are off. Therefore what you should do is add some parasitic capacitors on the net 17 and 22. For example, connect a 10aF capacitor to the floating nets and you'll be done. Hope it helps though it's a very late answer) Of course, it might help future readers..
