I couldn't find any specific reference to this problem, but why are you using a (roughly) 10 year old version of the simulator? There have been 9 major versions of the MMSIM/SPECTRE since then, so even if this was a bug then, it's highly likely it's been fixed in the meantime.
Even if it was a known bug then, it's likely that the only fix was to use a newer version. You probably could turn off compilation by adding "-ac 0" to the spectre command line - if using ADE, this can be done via Setup->Environment and then in the usrCmdLineOptions add "-ac 0". I wouldn't normally recommend doing that, but given that you're using such an ancient version of the simulator, you probably don't care that much about performance...
