Aug 14th, 2024, 10:19am
frequency divider with second order SDM has abs jitter of half vco (Read 2411 times)
cmosa
IIT
Aug 28th, 2017, 6:40pm
I have prepared a verilog a model for frequency divider with second order SDM. The divided frequency output has absolute jitter of  half VCO cycle.
I can not figure out why.
Details of Model:
1. Started from integer frequency divider model from designer's guide. 2. modified it to accept N from a file
3. From my matlab code of SDM write N sequence to a file
Simulation Setup:
VCO clock (2.56GHz) fed to frequency_divider_sdm (fracN=0.5)
Output:
Output Frequency is correct 2.56G/98.5.
However it has absolute jitter of half vco cycle.
Please suggest me wherer I am going wrong
cmosa
IIT
Re: frequency divider with second order SDM has abs jitter of half vco
Reply #1 - Aug 28th, 2017, 6:41pm
Here is the code of frequency divider with sdm
