Oct 18th, 2026, 2:07am
calculating SNR from dft on Spectre (Read 2875 times)
iris
Aug 28th, 2017, 11:51pm
Hi
I simulate 8-bit current-steering DAC. Fsine=prime_number*Fsample/(number_of_dft_bins). I'm doing a transient simulation on Spectre, stop_time=(number_of_dft_bins/Fsample), and then using dft function on the output, to produce the SNR from SpectrumMeas.
I don't understand what exactly affects the noise floor, how does the dft calculate the noise floor? because changing the number of transistors in the DAC, fro example, changes the SNR.
Appreciate any help,
Iris
Re: calculating SNR from dft on Spectre
Reply #1 - Aug 29th, 2017, 2:29pm
Iris,
 Fin =  (prime number / number of FFT points) * sample,
 where number of FFT points > 2 * prime numbers
Adding more FFT points decreases the noise floor. It would be better
to use the spectrum function in the ViVA.
Remember that an ADC has quantization noise, so the noise floor is  limited by the 6.021* number of bits + 1.76 divided by the 10 dB (bin width/bandwidth).
