Jul 16th, 2024, 1:29am
Is there a way to implement this kind of RC model in veriloga? (Read 234 times)
ray0923
Dec 01st, 2017, 10:01pm
I am trying to implement a resistor and a voltage dependent capacitor in series. I know i can use ddt to implement a voltage dependent capacitor but with resistor in series, the voltage drop on the capacitor is not really straight forward to derive. It seems recursive to me.
Re: Is there a way to implement this kind of RC model in veriloga?
Reply #1 - Dec 1st, 2017, 11:34pm
There are two ways of adding a series resistance. First, you can simply add an internal node and an additional branch. For example, consider this nonlinear capacitor
module varactor(p, n);
inout p, n;
electrical p, n;
parameter real c0 = 1p from (0:inf);   // nominal capacitance (F)
parameter real c1 = 0.5p from [0:c0);  // maximum capacitance change from nominal (F)
parameter real v0 = 0;			// voltage for nominal capacitance (V)
parameter real v1 = 1 from (0:inf);    // voltage change for maximum capacitance (V)
real q, v;
analog begin
    v = V(p,n);
    q = c0∗v + c1∗v1∗ln(cosh((v – v0)/v1));
    I(p, n) <+ ddt(q);
You can modify this model to add a series resistance as follows:
inout p, n;
electrical p, n, int;
parameter real r = 0 from [0:inf);     // series resistance (Ohms)
branch (p, int) res;
branch (int, n) cap;
real q, v;
analog begin
    v = V(cap);
    I(cap) <+ ddt(q);
    V(res) <+ r * I(res);
Alternatively, you use an implicit formulation:
inout p, n;
real q, v;
analog begin
    v = V(p,n) - r*I(p,n)
    I(p, n) <+ ddt(q);
« Last Edit: Dec 2nd, 2017, 10:09am by Ken Kundert »
ray0923
Reply #2 - Jan 9th, 2018, 2:34pm
Is that the same if i replace i(res) with i(cap)?
Reply #3 - Jan 9th, 2018, 3:41pm
More words are required.
Reply #4 - Jan 10th, 2018, 6:22am
I think the question is whether one can replace "I(res)" in the second line:
    I(cap) <+ ddt(q);
by "I(cap)".
While I(cap) and I(res) are equal by KCL, the matrix stamps (what the simulator sees when trying to solve the circuit) are different. Maybe it reduces to the same thing, but why would you want to do this?
