Sep 26th, 2026, 11:30pm
Varactor Simulation and Plotting the graphs? (Read 4519 times)
umberabbas
Feb 07th, 2018, 7:08pm
I want to use MOSFET as a MOS-cap varactor (both inversion and accumulation mode). I have first tried it with the inversion mode by connectiong the body to the Vcc. I did the DC analysis for the MOSFET and I am getting the following curve but I want to have it like C vs Vg, C vs Vtune and Vtune vs Freq. Kindly tell me how can i get it.
umberabbas
Re: Varactor Simulation and Plotting the graphs?
Reply #1 - Feb 7th, 2018, 7:43pm
simulator lang=spectre
global 0
parameters vcntrl=100m Vg=100m
View name: schematic
C1 (net4 net03 0) nvar_12rf w=(2u) l=(2u) ny=3 nx=3 m=1
Vg (net4 0) vsource dc=Vg mag=1m type=sine freq=60G
Vcntrl (net03 0) vsource dc=vcntrl type=dc
checklimitdest=psf
ac ac freq=60e9 param=Vg start=10m stop=300m step=10 annotate=status
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
dc dc param=vcntrl start=10m stop=300m step=0.1 oppoint=rawfile \
save C1:1 C1:2
umberabbas
Reply #2 - Feb 7th, 2018, 7:45pm
These are the generated graphs
Reply #3 - Feb 8th, 2018, 5:06am
Most MOSFET models don't include non-quasi-static effects, or what they have available is NQS for the channel current. I think to get the C vs freq plot, you need a model that accounts for "dynamic inversion charge" as described in the manual for the MOSVAR manual (developed originally at Arizona State, but now maintained by the Compact Model Coalition).
Reply #4 - Feb 8th, 2018, 9:08am
To see C as a function of Vtune, simply perform an AC analysis at a fixed frequency while sweeping Vtune. Plot the current through the capacitor. As long as there is no series resistance or non-quasistatic effect, you are free to choose the frequency for your convenience. I recommend choosing a frequency that allows you to scale the current so directly see the capacitance in Farads.
