Dec 7th, 2025, 11:15am
Support for AMS Simulation " Connect rule are not found in your AMS isntallation (Read 2770 times)
FDU2012crm
tokoyo
May 14th, 2018, 9:40pm
   I am trying to study the AMS simulation for mix-signal system. However when i follow the tutorial for amsPLL and try to the AMS simulation in ADL.
   I try to set the connect rule in setup. " Connect rule are not found in your AMS isntallation" appears. I cannot do any thing.
     (1) I have installed IUS92 and  connectLib are in lib manager
     (2) AMS_HOME is set to  IUS92 install directory.
would some like to help me ? Many thanks! Cry
Re: Support for AMS Simulation " Connect rule are not found in your AMS isntallation
Reply #1 - May 19th, 2018, 12:48am
Before wasting too much time, I wonder why you are using such an ancient version of the simulator?
There have been many, many releases since then - there's no reason to be using something so old.
