Horror Vacui
I do not need to do this, I just found the idea of saving the already post-processed simulation results from a verilogA module promising.
I have a verilogA block which does my sweep control for two variables and writes the results into a textfile, from where I can plot the necessary data. Otherwise I should run too many spectre runs, where most of the runs will not have a meaningful result (=the circuit can not function as intended). One of the simulation results are what is the range where the circuit operates. I find it non trivial to let it plot in Cadence, but I find it very easy to just write it into a text file. Since I have to write into a file the idea emerged that I could add another data to it as well.
One of the problem is that the output text file where I save the results from the verilogA module, takes its filename from the block properties. I run the same testbench with different config views, with and without parasitic extraction. It would be a great help if I could change some things in the outputs, what I have to write manually before every run if something changes: output filename, what config view has been run, which LPE view has been used, which corner is it on, date, because it might change after copying, but I could think of another information to archive. It does not need to be SKILL, it can be anything, C, Fortran, Pascal, Java, I just wondered whether it is possible.
