Jul 22nd, 2024, 1:24am
oceanEval statement in Monte Carlo simulation in Spectre to expert current (Read 1718 times)
pennyWWW
Jun 20th, 2018, 10:19pm
I try to export the current in the monte Carlo simulation but failed.
Could someone help me?
The following is an example of a PMOS.
I want to record the PMOS source-drain current.
It seems in the export mc.mcdata file the export values are just voltage of Dp(3.3) and Sp(0). I could not get the current value flowing through Sp node.
Is there some one can help with the oceanEval statement?
Follows are my script.
parameters vgp=3.3
parameters vdp=3.3
parameters wp=1.15u
nP (Dp Gp Sp vdd) pch_33 l=500n w=wp
VSp (Sp 0) vsource dc=0
VDp (Dp 0) vsource dc=vdp
VGp (Gp 0) vsource dc=0
mc1 montecarlo variations=process seed=10000 numruns=37 savefamilyplots=yes {
dc1 dc
export i1=oceanEval("i(\"Sp\")")
export v=oceanEval("v(\"Dp\")")
Thanks!
Penny
Re: oceanEval statement in Monte Carlo simulation in Spectre to expert current
Reply #1 - Jun 23rd, 2018, 2:16am
Hi Penny,
You appear to be trying to measure the current on a node, which makes no sense (currents flow through branches or through device terminals). It should be:
export i1=oceanEval("i(\"VSp:p\")")
This is the "p" terminal of the voltage source connected to the source. You could also use :1 instead of :p.
In case you add more analyses, for safety the expression should also say which analysis it's from too:
export i1=oceanEval("i(\"VSp:p\" ?result 'dc)")
pennyWWW
Reply #2 - Jun 26th, 2018, 3:59pm
Thanks so much!
It works!
Best,
Penny
Andrew Beckett wrote on Jun 23rd, 2018, 2:16am:
Hi Penny,
