Dec 14th, 2025, 12:38am
Floating node using spectre option (Read 4912 times)
Gp
Jul 30th, 2018, 5:31am
Hello All,
How can I found floating node in design using spectre option?
Another question is, any difference between the floating and dangling node?
Thanks.
Re: Floating node using spectre option
Reply #1 - Aug 1st, 2018, 7:14am
A dangling node usually means there's only one connection (but it's a resistive path). If you had
r1 dangle 0 50
then "dangle" is dangling, but not floating.
If you had
c1 dangle 0 1p
or if you have
c1 float 0 1p
c2 float 0 2p
then these nodes are both floating -- no dc path to ground. But "float" has two connections, so it's not considered dangling.
Horror Vacui
Dresden, Germany
Reply #2 - Jul 24th, 2019, 5:32am
Is there any spectre option which could REPORT any potential floating and/or dangle instances? It could be a useful way to narrow down the cause of convergence issues.
Reply #3 - Jul 24th, 2019, 11:46am
The topology checker naturally finds, reports, and fixes nodes without a DC path to ground, which includes floating nodes. Dangling nodes do not cause convergence issues as long as they have a DC path to ground.
Dynamic floating nodes (generally caused by Verilog-A models) are not reported with a dedicated message. Instead, the simulation fails with a 'Singular Jacobian'. When it does, it generally reports the nodes or branches where the problem was found. This often leads you to the problematic node or branch.
