Jul 22nd, 2024, 11:26pm
Simulating with long-time constants in high data-rate designs (Read 880 times)
sandman
Aug 21st, 2018, 2:57am
I could not find a previous post that matched this, so please excuse if this has already been answered!
I have a generic circuit that transmits/receives pseudo-random data at very high data rates. It is trivial to run a transient simulation at this data-rate in Spectre, without issues.
Suppose I include, say, an integrator in some feedback loop involving said generic circuit, and the integrator has a very large time-constant (several orders or magnitude slower than the input data-stream), what might be the best method to simulate the (time-domain) behaviour of the generic circuit with the feedback loop, while simultaneously having high-speed data in signal path?
I would be equally thankful for workarounds!
cheers,
sandman.
« Last Edit: Aug 21st, 2018, 7:02am by sandman »
rf-design
Reiner Franke
Re: Simulating with long-time constants in high data-rate designs
Reply #1 - Aug 21st, 2018, 4:20pm
You could benefit from a true multi-rate simulator in terms of runtime only if a small part of your circuit have fast nodes. Muti-rate is still in research and peak a decade ago. There are some but not many verification taks demanding what is more than a week runtime. So not enough return to spend on hard problems.
In your case the high-data.rate circuit consume most of CPU because it have to generate to input to the integrator.
