Sep 16th, 2024, 11:58pm
what are the port in the digital design (Read 391 times)
liletian
MD
Nov 02nd, 2018, 7:16pm
Hi
WHat are the port in the digital design? Are they referred to input and output? How about clock?
Can anyone please give an explanation or refer some documents?
Re: what are the port in the digital design
Reply #1 - Nov 3rd, 2018, 10:54am
This is a rather vague question - I can't even guess what you're hoping to get back as an answer or what your question means. My assumption is that you must be a student, in which case you should speak to your tutor or supervisor.
Maks
San Jose
Reply #2 - Nov 13th, 2020, 11:06pm
In general, a "port" is a point of connection of a net to the "external world".
The "external world" may be a higher hierarchy level cell/design, or a pad, or a pin of a chip/package.
The term "port" is use din both digital and analog designs.
In layout, "port" is often called "pin", which creates some confusion - because the term "pin" is often used for device instance terminals/pins.
