I tried to use spectre simulator to simulate a SPICE model of a power MOSFET and the SPICE model was imported following the instructions from
https://community.cadence.com/cadence_blogs_8/b/rf/posts/tip-of-the-week-how-to-...simulate-a-subcircuit-netlist-with-spectre-in-ade. The SPICE model can be found in
https://www.onsemi.com/PowerSolutions/supportDoc.do?type=models&rpn=NJT4031N... and its name is NTP75N03.sp3.
I could get the simulation to run but the result seemed not correct. The simulation was to get IV characteristic, i.e. Id vs Vgs and the schematic is shown in the attachment [img][/img]. The gate voltage is dc swept from 0V to 10V and drain voltage is constant 10V. According to the datasheet, threshold voltage is about 2V, but the simulated drain current was constant 0A.
Please take a look and I really appreciate if you could give some suggestions. Thanks.
