Sep 16th, 2026, 8:35am
Non-Linear Stability Analysis and Load Lines (Read 2325 times)
tec5c
Jul 22nd, 2019, 3:25pm
The non-linear stability analysis method through means of pole-zero identification states that the response is linearised about the large-signal periodic steady state (PSS) response. The literature also states that the HB simulation takes into account all the various states along the load line, when considering a power amplifier.
The pole-zero identification method makes use of a closed-loop transfer function. My question is, for every state along the load line there is (or should be) a corresponding transfer function. How can this method take various states along the load line into consideration and produce a single transfer function for stability analysis?
Re: Non-Linear Stability Analysis and Load Lines
Reply #1 - Jul 23rd, 2019, 1:42pm
If you are using SpectreRF and you are concerned about the stability of a feedback loop, then you would use the pstb analysis.
It is not computing large signal stability, but neither would the method you are describing. Instead, they report on the small-signal stability about a periodic operating point.
tec5c
Reply #2 - Jul 24th, 2019, 5:12am
Ken, thank you for your reply. However this doesn't answer my question. I'll try to simplify.
For a given PA, the device may be "taken" at any given point along the load line. How can a single transfer function of the circuit possibly "take all various load line states into consideration" as the literature claims?
Reply #3 - Jul 24th, 2019, 10:19am
SpectreRF simply linearizes the circuit about the periodic operating point, and then performs the small signal analysis about that operating point.
Essentially normal stability analysis linearizes the circuit about a DC operating point before applying the small signals required by the analysis. SpectreRF linearizes about the periodic operating point.  Thus, normal stability analysis determines whether a linear time-invarient approximation of the circuit is stable whereas SpectreRF determines whether the linear periodically varying approximation of the circuit is stable.
