To measure the sample bandwidth, use a PXF analysis where you sweep the output frequency from 0 to fs/2. Set max sidebands to something large, say 20-100. Run the analysis and plot the results including all sidebands by using the spectrum mode in direct plot. You can measure the sample bandwidth from the envelope of all the transfer functions.
To measure the bandwidth in track mode, simply turn off the clock and run an AC analysis.
