Dec 13th, 2025, 8:46pm
Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter (Read 2172 times)
jitter_grg
Jun 26th, 2023, 1:05pm
This is a plot of a 7 stage inverter based ring oscillator period jitter variance simulated using pss/pnoise. The k-cycle param is used from the direct plot main form.
Question 1: I can understand at Fmin of 100 due to flicker noise there is more deviation (on high side) compared to sqrt{k} in Jc. But, why the deviation to the other side (low side) as Fmin increases >10MHz ?
Question 2: This circuit has a free running oscillator, followed by a sync divider in reality. But, when simulating osc+divider the pss was not converging. Hence, the oscillator in itself was simulated and k-cycle accumulation was used to infer the divide-by-k function of the eventual sync divider. Is that a fair assumption, ignoring any inherent noise form divider ?
Appreciate your time and any advice you might have.
Re: Deviation of simulated Jc to calculated Jc , plus a question k-cycle jitter
Reply #1 - Jun 26th, 2023, 2:38pm
I'm afraid I have no explanation.  For the k-cycle jitter to stay constant or decrease with k implies that the signal is locking to a stable signal.  Does such a signal exist in your simulation?
jitter_grg
Reply #2 - Jun 26th, 2023, 2:52pm
No such stable signal exists in the deck. I assume you mean another frequency tone which is non-drifting and stable.
The deck has supply/gnd and 7-stage inverter based ring oscillator for these numbers. The ring itself is a free-running oscillator.
Anyway that was the question 1. Interesting that it only happens at high enough value for Fmin. At slightly lower Fmin values Jc matches sqrt{M} factor, and at still lower Fmin Jc deviates from sqrt{M} factor due to Jee. The last two parts are as per expectation.
Any comment on question 2 ? Basically for a free running osc+ sync divider combo, is the jitter at sync divide-by-k output same as looking at jitter at oscillator output with k-cycle param in direct plot main form ?
Reply #3 - Jun 26th, 2023, 3:17pm
I can't really comment on that as I am not familiar with how the data is processed to extract the k-cycle jitter.
