Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 15
th
, 2024, 7:31pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Is CDL case-sensitive?
‹ No topic |
Next topic
Is CDL case-sensitive? (Read 155 times)
May 14
th
, 2024, 2:00pm
Is the CDL netlist format case-sensitive? Andrew Beckett posted a link that led me to some Pegasus documentation:
https://support.cadence.com/apex/techpubDocViewerPage?path=pegasusref/pegasusref...
21.31/app_pegasus_cdl_ct_CDL_Syntax_Rules_.html
It doesn't say explicitly, but the syntax for a MOS instance line uses L and W, along with lower-case node names:
M0 d g s b N W=.5 L=.2 M=4 $LDD[LDDN] $NONSWAP
IP Logged
‹ No topic |
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
