Paul
> Spectre also provides a non-Monte Carlo based mismatch analysis. Have you tried it?
Mighty Mouse,
I am not aware of this analysis. I am mostly using ELDO, but I would be interested in this Spectre feature. What Analog Environment menu can I find it in?
For the binning problem, I don't have any solution, I used this with non-binned models (older technology). I agree that you should try to get support from Cadence for this bug. BTW, there is a third possibility I didn't mention in my first answers. If you have an EKV model (instead of BSIM), this model contains the mismatch parameters in the model, so there's no need to go the subcircuit way... Unfortunately, EKV doesn't seem to become an foundry standard.
Paul
