ENNIOJ82
Hi , I had to do a script ocean that take the result from a montecarlo analysis Resul directory ./Sim....../psf and put them into a array o a list..... The result must be in like Num iter;OUT_27 ( a result for every Run ) OUT_27 is a parameter of the analysis It should be a result like IterVsValue("OUT_27") but this return the result on screen ,instead i had to print this in a list..... Can someone help me? Thanks
