Aug 15th, 2024, 1:21pm
P noise in cadence spectre (Read 2653 times)
rjshmadala
Jan 08th, 2006, 3:38am
Hi Guys,
when i was running pnoise analysis in cadence spctre it saying as below
Internal error found in spctere during p noise analysis please run 'get spectre files' or send the netlist..............
to support@cadence.com
assertion failed in file 'bsim3v3.c'at line 44995
assertion failed.
pss was running correctly
can u guys please solve this issue.
i set the parameters as in cadence manual
http://www.cadence.com/community/virtuoso/resources/SpectreRF_VCO533AN.pdf
but still the error  was coming.
Rjshmadal
Re: P noise in cadence spectre
Reply #1 - Jan 9th, 2006, 10:29am
This looks as if it may be the same as PCR:
   PCR: 756235
 Title:  Assertion failed in file bsim3v3.c during Pnoise
which was fixed in an IC5141 hotfix (and later), in at least 5.10.41.500.0.9. It doesn't look as if the fix was
backported to IC5033. The assertion failure was not on the exact same line, but the code would have changed
between versions anyway... It may not be exactly the same problem though...
Can you try in a more recent version?
