Aug 17th, 2024, 3:23am
Parasatic Resistance in Post Layout Simulation (Read 157 times)
Faisal
Apr 18th, 2006, 7:38am
I am making my post-layout simulation and only the parasatic capacitances are extracted and not the parasatic resistances by Cadence Virtuso. Are there any ways to extract the resistances as well with the Cadence?
If not, what are the alternatives to cater for this parasatic resistance ?
bernd
Munich/Germany
Re: Parasatic Resistance in Post Layout Simulation
Reply #1 - Apr 18th, 2006, 9:40am
Yes there are ways to extract parasitics R's.
First off all Cadence is the name of the company.
Cadence Virtuoso is the name of the product family, but
commonly know as the name of the layout editor tool.
You don't do parasitic extraction with a company or
a layout editor tool!
There are two (three, but I forget about Dracula) tools available
form the Company Cadence to do parasitic extraction, Assura and Diva.
With Assura parasitic R extraction is setup together with
C extraction, I don't think that people who simulate and compile the
parasitic models for your process design kit exclude R's.
The option to extract R's can be chosen over the GUI
( Tab "Extraction", Extraction Mode == RC ).
With Diva this has to be defined in your 'divaEXT.rul' file
form your design kit, maybe is it not defined, maybe you have
to set an explicit switch in the GUI for R extraction.
If you use Diva you should check this file for
'measureResistance' statements, if it contains some
it's likely that you can extract parasitic R's with you rules.
Bernd
Just another lonesome cad guy
ACWWong
Oxford, UK
Reply #2 - Apr 19th, 2006, 6:59am
Yes you can set the switches to extract resistance is Assura or Diva as mentioned, assuming that someone (the foundry) has created the relevant extraction rules.... i have experienced three cases of :
1) R extraction work fine ... hurrah
2) R extraction rules work, but the calculations were wrong !
3) No R extraction catered for at all....
Also beware of increased netlist due to resistance extraction, it produces a lot more nodes in a circuit than just capacitance extraction.
