Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 27
th
, 2026, 8:59pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Plotting the frequency of a VCO versus time
Previous topic
Next topic
Plotting the frequency of a VCO versus time (Read 4688 times)
RFICInDaHouse
Oct 09
th
, 2006, 6:36pm
Hi Guys,
I want to examine the transient response of a quadrature oscillator as I force it to an initial unstable state. I run a transient analysis and I observe the oscillator behavior as it converges to its steady state. During this process, the oscillation frequency changes with time untill it stabilizes. I would like to get your opinion on how to plot the oscillation frequency versus time? Note when I use the calculator and choose the "Frequency" function I only get the steady state frequency. Thanks for your help in advance.
IP Logged
ACWWong
Oxford, UK
Re: Plotting the frequency of a VCO versus time
Reply #1 -
Oct 10
th
, 2006, 1:18am
I would use a verilogA block which counts crossings... if you use cadence there is a freq_meter in ahdlLib or try
http://www.designers-guide.org/VerilogAMS/index.html
if using freq_meter there a couple of things you might want to bear in mind: the Nature Frequency blowup limit is default 1G. You might want to modify it to something bigger; and the accuracy will suffer depending on your timesteps... so using a maxstep might help.
IP Logged
RFICInDaHouse
Reply #2 -
Oct 10
th
, 2006, 10:14pm
Thanks, that worked just fine!. For you who are interested in this thread, you need to setup the "blowup" parameter of the "FF" above some critical value that depends on your circuit transient response. The syntax and the procedure for doing so in Spectre is as fllows:
1_ Create a blowFF.scs file in your favorite directory and add the following script:
temp quantity name="FF" units="Hz" blowup=15e+09
2_ Note that 15+e09 was the critical frequency for my circuit and you can adjust it as needed
3_ From the Analog Artist, go to Setup-->Model Libraries..., browse for the blowFF.scs file and Add it.
4_ you can adjust the abstol(FF) for better resolution by accessing the verilog.va file of the freq_meter component.
That worked for me.
Thanks again ACWWong
IP Logged
Reply #3 -
Oct 14
th
, 2006, 10:27am
A simple approach that may also suffice -
Plot the VCO control voltage.
That is going to be proportional to frequency, and show most of the performance issues associated with lock aquisition, overshoot, etc.
Might suffice in most situations...
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2026
Designer’s Guide
All rights reserved.
Send comments or questions to
[email protected]
. Consider
submitting
a paper or model.
