neoflash
![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/starsilver.gif)
![](http://avatar.elektroda.net/gallery/00fun/download.php-1072.gif)
Mixed-Signal Designer
Normally, those passive elements will be a w-element, or a touchstone file. They will either be represented by a subckt, or special instance in cadence library.
However, cadence analogLib does not support w-element instance and s-parameter instance. Currently, we manually edit spice netlist and add those passive elements into the circuit.
Any suggestion to make those passive elements could be directly extracted from schematic?
