Jul 17th, 2024, 10:27am
RSCE (Read 1202 times)
sivacharan
RSCE
Jan 10th, 2007, 11:14pm
Can any one explain simply the physics behind the Reverse Short Channel Effect??
Thanks.
Re: RSCE
Reply #1 - Jan 11th, 2007, 11:45am
mc66
Re: RSCE
Reply #2 - Jan 13th, 2007, 3:22am
it's because halo implant,which is use to prevent punch through
when L decrease,and before SCE take effect,the halo implant will make the effect doping of sub rise,so vt rise
Croaker
Re: RSCE
Reply #3 - Jan 15th, 2007, 4:40pm
mc66 wrote on Jan 13th, 2007, 3:22am:
Perhaps I can clarify...and see if I understand...
There is a p-type halo implant around the s/d.  This high p-doping decreases the width of the depletion region, thus making it harder for the depletion regions of the s/d to touch, which is important when the channel is short.
For long-channel devices, the halo implant is a pretty insignificant portion of the p-type substrate doping.  As the channel shrinks, more of the channel consists of this high p implant, and thus the threshold voltage increases (the charge concentration is higher).
Makes sense to me.   Smiley
mc66
Re: RSCE
Reply #4 - Jan 17th, 2007, 4:42am
Croaker wrote on Jan 15th, 2007, 4:40pm:
you are right,and express clearly.i'm chinese,so express something use english is difficult to me
Croaker
Re: RSCE
Reply #5 - Jan 17th, 2007, 6:30am
No problem.
