Jul 17th, 2024, 12:31pm
Shot Noise Model of BJT  in Spectre (Read 4385 times)
AnalogAroma
Sep 13th, 2006, 10:30am
Hi All,
       I  would like to know how  in Spectre collector shot  noise is correlated  to the electron current noise  originated in the base -emitter junction. Are they still using the old idea of collector partition noise ?
      With Regards,
                       Analog Aroma
ACWWong
Oxford, UK
Re: Shot Noise Model of BJT  in Spectre
Reply #1 - Sep 13th, 2006, 3:16pm
AnalogAroma wrote on Sep 13th, 2006, 10:30am:
Hi All,
      With Regards,
                       Analog Aroma
When you say spectre, i guess it depends more actually on the model used. I don't think SGP or standard VBIC have any correlation of base shot noise to collector shot noise. I think i have read somewhere that the phillips model (Mextram) has it (physical charge partitioning model rather than emprical extracted) and so more accurately gives NFmin at very high frequency.....
Of course if you are really keen you could code the correlation yourself in your own model...
Look at the under modelling of the designers-guide.org to see veriloga examples of various bjt,hbt models.
cheers
aw
mg777
Reply #2 - Jan 17th, 2007, 12:22pm
I would be less worried about approximations made in shot noise as opposed to 1/f noise.
M.G.Rajan
www.eecalc.com
