Jul 16th, 2024, 11:43am
Mathcad model fractional pll (Read 3136 times)
dhirajv12
Jan 31st, 2007, 4:07am
How can I model the second order sigma delta for the fractional pll.
How I can I show the bit sequence which is fed to the divider has LSB's changing from 1 to 0 which provides the average value of the division factor required.And how to print the average value.
Is there any specific equation set for this.
Can you give the source where I can get a matchcad model for this purpose.I have a model of sigma delta converter which plots the quantization noise plot with respect to frequency.How is this applicable to fractional pll
regards
dhiraj
imtired
Santa Rosa
Re: Mathcad model fractional pll
Reply #1 - Jun 5th, 2007, 2:13pm
Hi dhiraj,
I'm having a hard time understanding your question.
Are you trying to simulate the frac-N PLL in the time domain?
Or are you trying to model the phase noise / stability of the frac-N PLL?
Robert
