Oct 31st, 2024, 5:43pm
illegal library definition found in netlist ... (Read 2851 times)
int2
Aug 09th, 2007, 10:29pm
Hi everyone,
I'm pretty new to Cadence. When trying to simulate a simple inverter with Spectre, I got the following error:
/lib/src/models/XX-XXX--X/md121-xxx.scs 101: Illegal library definition found in netlist
The library I received from the foundry. What should I do now ?
I already included this line in bashrc:
export CDS_Netlisting_Mode=Analog
Re: illegal library definition found in netlist ..
Reply #1 - Aug 27th, 2007, 2:01pm
My guess is that you're including the model file which has got a library definition within it. When you include a model file with a library in it, you need to specify the name of the "section" that you want to include (this is often the process corner that you're trying to simulate). Take a look at the model file and see if it has libraries and sections within it, and make sure you're giving the section name in the include statement:
include "file" section=NN
for example - or in ADE, in the model libraries form, specify the section name there.
