Better still use the capability in recent versions of spectre (I think it was introduced in MMSIM61, although it may have been MMSIM60) to save "state". There are a number of options to the tran analysis which allow you to specify times to save the state, or the wall clock period to save the state (similar to the checkpoint options that Alan suggested). As with checkpoint, these may be recovered using the recover options.
The benefit is that this saves a complete state, and tends to be more robust in restarting.
