Hi Oslo,
if I understood you problem right from my point of view it is not possible, as you want to perform one simulation, compute a result and run a second simulation afterwards. This is not supported by ADE. There are two possibilities:
1. use ocean-scripting, i.e. see
http://www.designers-guide.org/Forum/YaBB.pl?num=11382027842. create a VerilogA-model of a voltage controlled resistor, setup a transient simulation with some clock to get the required voltage, switch the clock and provide to required resistance
Or do you just need a voltage controlled resistor? Then it is just a little VerilogA-scripting
like
I(node1, node2) <- V(node1, node2) / (R0 * V(control))
Achim
