Jul 16th, 2024, 5:37pm
Weird results from PAC simulation (Read 5613 times)
harmonics
Feb 26th, 2008, 12:55am
Recently I encountered some problems with PAC simulations so I decided to test the PAC simulation.
I built the simple RC circuit with the R replaced by a switched capacitor CR as shown in the following figure:
Vin -------(phi 1) -------(phi 2) ----------Vout
                         ------  CR
                          gnd
phi1 and phi2 are non-overlapping clocks controlling two NMOS switches respectively.  Vout is connected to the ground (gnd) through another capacitor (not shown).
To verify the simulation issues, I constructed three similar circuits as follows (all with same input Vin and clock signals):
Circuit (1): NMOS model set 1, Vout = vosci
Circuit (2): NMOS model set 2, Vout = vosc
Circuit (3):  Switched capacitor CR is replaced by its equivalent resistor R, Vout = vorc.
PSS simulations are similar for vosci and vosc while vorc is simply a dc voltage as expected.  However, when proceeding to perform the PAC simulation, I obtained the following results (see attached).
From the graphs, it can be seen that vosci (Circuit 1) and vorc are as expected from simple RC circuit but vosc (Circuit 2) is very odd with a gain of below -100dB.
As the only difference between Circuit (1) and Circuit (2) is the NMOS model (BSIM3), could anyone help me solve the weird PAC results mystery?  Thanks!
Frank Wiedmann
Munich, Germany
Re: Weird results from PAC simulation
Reply #1 - Feb 26th, 2008, 1:32am
Simplistic VerilogA models can show such behavior, see http://www.designers-guide.org/Forum/YaBB.pl?num=1199890595. However, I have never heard of such problems with BSIM3 models.
harmonics
Reply #2 - Feb 26th, 2008, 10:56pm
Hi Frank,
Thanks for replying.  I have absolutely no clue which of the BSIM3 model parameter(s) cause such PAC problem.  I tried to compare the two sets of NMOS BSIM3 models and found that the one in Circuit (1) uses version 3.2 and Circuit (2) uses version 3.3.  Also, there are some differences between the two models but majority of the parameters are defined (although the values are slightly different).
Could it be due to some missing parameters in the BSIM3 version 3.3 in Circuit (2)?
Frank Wiedmann
Munich, Germany
Reply #3 - Feb 26th, 2008, 11:29pm
Might be. You can find the official documentation on BSIM3 at http://www-device.eecs.berkeley.edu/~bsim3/. If you have access to Cadence support, you could also send them your test case as there might also be a problem with the implementation of BSIM3 in SpectreRF.
You could also try to see what happens if you use the parameters of the new version 3.3 model with model version 3.2. I don't recommend that you use such a model for your design but it might give you some further hints on the cause for the problem.
Reply #4 - May 21st, 2008, 12:14pm
Version 3.2 is rather old; there were some bugs fixed in intermediate versions.  You could also try just changing the version number (try 3.24).
Did you try some basic dc i/v curves over the voltage range you're working with?
-Geoffrey
(Post #1000!)
Reply #5 - May 21st, 2008, 1:56pm
SpectreRF is telling you that there is no path for the signal from the input to the output. That may be due to the model, but more likely there is something wrong with your circuit. Perhaps your switch transistors are not turning on? Try debugging the circuit.
