Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 7:27am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› how to use cmdmprobe in stb analysis
Previous topic
Next topic
how to use cmdmprobe in stb analysis (Read 855 times)
Julian18
Feb 26
th
, 2008, 4:40am
hi, there.
i want to analysis the stability of this full differential OTA(shown below), how to add the cmdmprobe into this circuit to do the stb analysis?
Thanks.
IP Logged
James Bond
Re: how to use cmdmprobe in stb analysis
Reply #1 -
Feb 26
th
, 2008, 4:45am
I think there is a component in the analoglib called iprobe, in order to use that , you need to put this component in between your common output from opamp and cmfb input, and run stb analysis. Hope it will help.
james
IP Logged
Frank Wiedmann
Munich, Germany
Reply #2 -
Feb 26
th
, 2008, 4:53am
See
http://www.designers-guide.org/Forum/YaBB.pl?num=1190707743/1#1
. Connect the positive output via the cmdmprobe with the negative input and vice versa.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
