I can't find any design issue in your post.
Your question is not design issue but simple usage of EDA tool.
Please post to "The Designer's Guide Community Forum ≫ Simulators ≫ RF or Circuit Simulators". manodipan wrote on May 16th, 2008, 3:11am:I am facing some problem in getting the ac behavior(gain and phase) for a simple switched capacitor integrator.The continuous time version of the circuit with resistors is working perfectly,but resistors replaced by switched capacitors is giving me proper transient response but not ac response.can u guys suggest some solution?pls reply asap.
Use a pulse wave having narrow width as input, then do FFT(DFT) of output transient waveform.
You can use this method by any Spice type transient simulator.
If you have SpectreRF of Cadence, use Shooting-PSS/PAC.
See
http://www.designers-guide.org/Analysis/sc-filters.pdfYou can also do same tasks using HSPICE-RF of Synopsys, SmartSpiceRF of Simucad, EldoRF of Mentor or NEXXIM of Ansoft, etc...
Attached figure is simple example of BP-SCF and corresponding BP-CTF.
