Jul 17th, 2024, 10:36pm
VCO phase noise (Read 2756 times)
Faisal
VCO phase noise
Jun 18th, 2008, 7:21am
I have a question related to phase noise simulation of a "free running VCO" in SpectreRF. Using pnoise analsyis, I am able to see a phase noise value of about -55 dbC at 1 KHz.
However at lower offset frequencies such as 1, 10 and 100 Hz.. I see a ridiculously high values such as 30 dbC (i.e. even higher than the carrier). I know that this is not possible in reality, but there must be some explanation to this weird result (Most probably the pnoise settings)
Any ideas, here?
Hyvonen
Re: VCO phase noise
Reply #1 - Jun 18th, 2008, 7:56am
What's the amplitude at the fundamental oscillation frequency?
At very low frequency offsets flicker noise dominates the phase noise, (usually) with a ramp of 30dB/dec.  I've never simulated all the way down to 1Hz, but overall I think it makes sense that the simulation result for low-offset phase noise would be higher than the carrier power (although this is not physical).
Frank Wiedmann
Munich, Germany
Re: VCO phase noise
Reply #2 - Jun 18th, 2008, 8:28am
