Jul 16th, 2024, 12:53pm
How to perform the PSS+PNOISE for a divider? (Read 3117 times)
Tuc
Jul 2nd, 2008, 8:41pm
Hi, Gentlemen,
I want to simulate the phase noise of a divider circuit, however, I'm a little confused with the PNOISE settings:
(i). How to set the output frequency range? The frequency supposed to be get after dividing?
(ii). The input frequency range? which is calculated by the simulator itself after setting the output frequency range. For example, suppose the divider ratio is 4, and the output frequency after dividing is 100M, I got the following message from the simulation log:
Periodic Noise Analysis 'pnoise': freq = 100 MHz +  (1 KHz -> 1 MHz)
Input frequency range = 400 MHz + (1 KHz -> 1 MHz).
Is it reasonable for the value "Input frequency range" calculated by the simulator? What does it mean in the divider??
--Tuc
« Last Edit: Jul 03rd, 2008, 12:05am by Tuc »
Re: How to perform the PSS+PNOISE for a divider?
Reply #1 - Jul 6th, 2008, 5:44am
Show me netlists about PSS and Pnoise.
Tuc wrote on Jul 2nd, 2008, 8:41pm:
Output frequency of Pnoise is not divided since it is small signal.
Maybe you set iprobe and reference band in Pnoise. So it is very reasonable as input frequency.
You don't have to set iprobe and reference band in your case.
You can observe noise at freq=N*PSSfund+/-(1kHz~1MHz) with setting sweeptype=relative relharmnum=N in Pnoise.
http://www.designers-guide.org/Forum/YaBB.pl?num=1211952319/3#3
« Last Edit: Jul 6th, 2008, 7:55am by pancho_hideboo »
Tuc
Reply #2 - Jul 6th, 2008, 7:02pm
Thank you very much Pancho, you're right.
-- Tuc
