Jul 16th, 2024, 2:40pm
QPSS simulation for Mixer with LO dividers (Read 1263 times)
Tuc
Jul 03rd, 2008, 12:02am
Hi, guys,
I'm running QPSS (Flexible Balance) for mixers with LO dividers, however, the speed is untolerable. It takes about 5 hours for one QPSS iteration!!
Is there any methods to speed up the simulation? Thanks very much.
-- Tuc
Stefan
Re: QPSS simulation for Mixer with LO dividers
Reply #1 - Jul 3rd, 2008, 12:54am
With so few information, the only possible hint is to simplify your circuit ... check your frequencies, maybe you can skip the RF divider using PWLs ...
View Profile 16731287   IP Logged
Reply #2 - Jul 3rd, 2008, 6:13am
Tuc,
  Some information would be useful in assisting you,
What are the clock and input frequencies?
What are the divide ratios?
Are you using the freqdivide option?
How many tones/fundamental are you using?
Do all the tones at the same frequency have the same fundname
or do you have different fundnames for I,Q,I_, and Q_?
Tuc
Reply #3 - Jul 3rd, 2008, 6:27am
Thank you very much for your reply, Sheldon and Stefan.
-- The clock is around 100MHz, input frequencies is at the same level.
-- Four.
-- Yes, I did.
-- Two tone at the RF input (100.5MHz and 100.6MHz), and one tone at LO (400MHz, after dividing should be 100MHz).
-- No same freq.
-- ? I do not catch this question, sorry.
Tuc
Reply #4 - Jul 3rd, 2008, 6:45am
Tuc wrote on Jul 3rd, 2008, 12:02am:
Show me portions of your netlist regarding signal statement,  analysis statement and option statement.
Also show me version of your Cadence Spectre.
http://www.designers-guide.org/Forum/YaBB.pl?num=1205223090
http://www.designers-guide.org/Forum/YaBB.pl?num=1208334972
http://www.designers-guide.org/Forum/YaBB.pl?num=1208883935
Tuc
Reply #5 - Jul 3rd, 2008, 9:08am
Thank you, Pancho. Here's the related netlist:
PORT_lo (net063 0) port r=50 num=1 type=sine freq=flo_div dbm=plo_div \
       fundname="flo_div"
PORT_rf (vin 0) port r=50 type=sine freq=frf dbm=prf freq2=fund2 dbm2=prf \
       pacdbm=prf mag=1 fundname="frf" fundname2="fund2"
   checklimitdest=psf
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
sweepqpss  sweep  param=prf  start=-60  stop=-20  lin=1
+          values=[-40]  {
 qpss  qpss  flexbalance=yes  oversample=[4  1  1]
+       funds=["flo_div"  "frf"  "fund2"]  maxharms=[4  3  3]
+       errpreset=moderate  tstab=100n  annotate=status  freqdivide=4
The Spectre version is 6.1.0.151 -- 26 May 2006.
-- Tuc
Reply #6 - Jul 3rd, 2008, 5:35pm
Unless you need both upper and lower IM3, you can invoke 2 tone HB-QPSS/QPAC instead of 3 tone HB-QPSS.
Tuc wrote on Jul 3rd, 2008, 9:08am:
      fundname="flo_div"
In the above, flo_div is 400MHz ?
In the above, frf=100.5MHz and fund2=100.6MHz ?
+          values=[-40]  {
Why do you set lin=1 ?
Add restart=no  maxperiods=200.
And you had better increase maxharms of "flo_div".
It might be rather fast if you set tstab=0n.
Although HB-QPSS of SpectreRF is still very slow compared to Agilent ADS or GoldenGate even if I use current SpectreRF, I think its simulation speed is practical level.
But HB-QPSS of old SpectreRF such as 6.0USR1, 6.0USR2, 6.1 is very very very slow and doesn't converge at all in many cases.
So they are not practical usel level.
Since you are using fairly old SpectreRF, simulation speed will be still slow even if you do tuning of netlist.
I recommend you to update Spectre.
« Last Edit: Jul 4th, 2008, 9:13am by pancho_hideboo »
