Jul 16th, 2024, 12:32pm
Is S21 the actual gain of a LNA?? (Read 8992 times)
zhangjerome
Jul 11th, 2008, 6:48pm
There are three kinds of gain, power gain, transuducer gain, availble gain. Which one is the gain we concern??
In Spectre, with a 50 ohm port as the input, is S21 the gain of the LNA even the input is not well matched??
Re: Is S21 the actual gain of a LNA??
Reply #1 - Jul 11th, 2008, 10:38pm
zhangjerome wrote on Jul 11th, 2008, 6:48pm:
S21 is a transducer gain.
You have to learn measurements using actual instruments. Not "EDA Tool Play".
« Last Edit: Jul 12th, 2008, 7:13am by pancho_hideboo »
zhangjerome
Reply #2 - Jul 13th, 2008, 4:23am
H, Pancho. As I know, the transducer gain is a function of S21 and other parameters, such as source and load reflection coefficients. Why do you think S21 is the transducer gain??
Reply #3 - Jul 13th, 2008, 7:26am
zhangjerome wrote on Jul 13th, 2008, 4:23am:
All incomplete knowledges are always useless.
You don't seem understand basic of RF. But this is not restricted to you.
1/S21 is a insertion loss.
Definition of insertion loss is same as inverse of sqrt(transducer gain).
See circuit theory text book, especially on filter design.
http://en.wikipedia.org/wiki/Power_gain
If you think the following, you must consider reference impedance of S-parameters definition. In the following, what values are used as reference impedances(Z01 and Z02) of S11, S12, S21, S22 ?
http://www.maurymw.com/support/faqs/faqs/faq9.html
Gamma_S=(ZS-conj(Z01))/(ZS+Z01), ZS is source impedance.
Gamma_L=(ZL-conj(Z02))/(ZL+Z02), ZL is load impedance.
If Z01=conj(ZS), Gamma_S=0.
If Z02=conj(ZL), Gamma_L=0.
Here these are not matching.
So S21=sqrt(Transduder Power Gain) is satisfied.
Usually ZS and ZL are real impedances such as 50ohm.
Again You have to learn measurements using actual instruments. Not "EDA Tool Play".
« Last Edit: Jul 13th, 2008, 5:24pm by pancho_hideboo »
zhangjerome
Reply #4 - Jul 13th, 2008, 6:21pm
Hi, pancho. Thank you for you patience.
Seems I get it. Both gamma_source and gamma_load are zero. So S21 is actully equal to transducer gain. Am I right?
