Jul 16th, 2024, 5:31pm
Simulate a Direct Conversion Mixer with Eldo-RF and ADMS (Read 14100 times)
trumpeu
Jul 21st, 2008, 11:11am
Hi
I was trying simulate a Direct Conversion Mixer with Eldo-RF and ADMS but the sources do not work good and the results off simulation is not agree.
The result don't show the constellation both the input and the output.
I will describe the SPICE and Verliog AMS archives:
Verilog Ams
Quote:
// Demodulator IQ
`include "discipline.h"
`include "constants.h"
module res (rf,ol,ol1,vif_i,vif_q);
     parameter real rin=50;                                    //input impedance
     parameter real rout=50;                                    //output impedance
     parameter real ganho=10;                              //Gain in db
     parameter real iip3=-10;                              //third order intercept point
       parameter real iip2=2;                              //second order intercept point
     inout rf,ol,ol1;
     output vif_i,vif_q;
     electrical vif_q,vif_i;
     electrical rf,ol,ol1;
     real va,vb,ga,ia,ib,ic,vd,F_r,c_ruido,gc,Aiip3,vin,vout,Aiip2,gb;
     analog begin
           @(initial_step) begin                              //Parameters conversion
                 ga = pow(10,ganho/20);                        //Gain conversion
                 Aiip3=sqrt(pow(10,iip3/10)*2*rout*0.001);
                 gc=(4/3)*ga/(Aiip3*Aiip3);
                 Aiip2=sqrt(pow(10,iip2/10)*2*rout*0.001);
                 gb=ga/Aiip2;
           I(rf)<+V(rf)/rin;
           I(ol)<+V(ol)/rin;
           I(ol1)<+V(ol1)/rin;
           vin=V(rf);
           vout=ga*vin +gb*vin*vin -gc*vin*vin*vin;
           V(vif_i)<+vout*V(ol);
           V(vif_q)<+vout*V(ol1);
Spice:
Quote:
.verilog resistor.vla
Vout 11 0 RPORT=50
*+MPSK m=8 lpf=no_filter
+MQAM M=16      LPF=no_filter BETA=0.35 IASC=1 QASC=1
+ four 1GHz MA (1) 50m 0
+ pattern delay=10n tsymb=50n RANDOM
Y1 res 11 12 13 22 31
+ param: iip3=-10 iip2=10  ganho=72
Vol  12 0 RPORT=50
+four FUND2 MA (1) 50m 0
Vol1 13 0 Rport=50
+four FUND2 MA (1) 50m 90
.modsst 5n 10u
.option hmax=1n
.option sst_tstop=1u
.param gan=-1
.SST fund1=1GHz NHARM1=3
+FUND2=1.1GHz NHARM2=3
.PLOT TMODSST V(11) V(22) V(31) V(12) V(13)
.PLOT FMODSST v(11) v(12) v(13) vr(22) vr(31) vi(22) vi(31)
.PLOT FOURMODSST FOURDB (v(11))
.PLOT FOURMODSST FOURDB (v(22))
.end
Thanks for atention
Ps. I use the tutorial http://www.designers-guide.org/Modeling/modeling-rf-systems.pdf for develop this situation
Ps. Sorry for the English
Re: Simulate a Direct Conversion Mixer with Eldo-RF and ADMS
Reply #1 - Jul 21st, 2008, 5:12pm
Why do you set local frequency(FUND2) as 1.1GHz while you state "Direct Conversion Mixer" ?
trumpeu wrote on Jul 21st, 2008, 11:11am:
What do you refer as disagreement ?
You seem to apply 16QAM signal with carrier frequency of 1.0GHz and Rsymb=20MHz as RF input signal.
Show me your constellation results.
To plot constellation you have to tune sampling timing of symbol.
I can't find even symbol_rate setting in your plot setup.
Do you understand difference of constellation and trajectory ?
For example, constellation function of Agilent ADS is like following.
   constellation(i_data, q_data, symbol_rate, delay)
Here symbol_rate and delay are required.
Even if there is no filter in your setup, you have to delay at least Tsymb/2-Tstep to plot constellation.
.SST fund1=1GHz NHARM1=3 FUND2=1.1GHz NHARM2=3
.modsst 5n 10u
Although I don't know eldoRF, I guess the above two statement combination is for envelope analysis.
In the above, there is no specification of harmonic to observe.
To plot constellation or trajectory of V(11), you have to specify harmonic=(1,0), that is 1GHz. Then plot {vr(11), vi(11)}.
While, to plot constellation or trajectory of V(22) or V(31), you have to specify harmonic=(-1,1), that is 100MHz. Then plot {vr(22), vi(22)} or {vr(31), vi(31)} .
In eldo/ADMS, where do you set such harmonics for envelope analysis ?
« Last Edit: Jul 21st, 2008, 8:26pm by pancho_hideboo »
trumpeu
Reply #2 - Jul 23rd, 2008, 8:15am
First thanks for the answer
pancho_hideboo wrote on Jul 21st, 2008, 5:12pm:
Sorry I wrote wrong in the last post. FUND2=1GHz.
If I use FUND1=FUND2=1GHz I obtain this constellation(Plot source with v(11).h(1,0)):
The plot off in and out has attach
IT's OK
But IF I will change the verilog source, add a second order intermodulation. I don't see the modification of constellation.
I'm thinking that the results of mixer h(1,-1) is different of the dc output h(0,0) but I would like to see in same time. What I think is correct?
Ok, I have used a EZWAVE for plotting the constellation, I have used a TCL archive for tune the sampling:
Quote:
evalExpression { setAngleUnits("degrees") }
evalExpression { setTemperatureUnits("celsius") }
evalExpression { wf0=mag(wf("<teste/FMODSST>V(11).H(1,0)"))}
evalExpression { wf1=mag(wf("<teste/FMODSST>V(22).H(1,0)"))}
evalExpression { saida=complex(wf("<teste/FMODSST>VR(22).H(1,-1)"),wf("<teste/FMODSST>VR(31).H(1,
-1)"))}
evalExpression { saida1=complex(wf("<teste/FMODSST>VI(22).H(1,-1)"),wf("<teste/FMODSST>VI(31).H(1
,-1)"))}
evalExpression { C2211=constellationdiagram(wf("<teste/FMODSST>V(22).H(1,-1)"),5E-8,35E-9) }
evalExpression { C1110=constellationdiagram(wf("<teste/FMODSST>V(11).H(1,0)"),5E-8,35E-9) }
evalExpression { C3111=constellationdiagram(wf("<teste/FMODSST>V(31).H(1,-1)"),5E-8,35E-9) }
evalExpression { C2210=constellationdiagram(wf("<teste/FMODSST>V(22).H(1,0)"),5E-8,35E-9) }
evalExpression { C2200=constellationdiagram(wf("<teste/FMODSST>V(22).H(0,0)"),5E-8,35E-9) }
evalExpression { C2220=constellationdiagram(wf("<teste/FMODSST>V(22).H(2,0)"),5E-8,35E-9) }
evalExpression { C2230=constellationdiagram(wf("<teste/FMODSST>V(22).H(3,0)"),5E-8,35E-9) }
evalExpression { saidadc1=wf("<teste/FMODSST>VR(22).H(0,0)")+wf("<teste/FMODSST>VR(22).H(1,-1)") }
evalExpression { saidadc2=wf("<teste/FMODSST>VR(31).H(0,0)")+wf("<teste/FMODSST>VR(31).H(1,-1)") }
evalExpression { saidadcc=complex(wf("<calc>saidadc1"),wf("<calc>saidadc2")) }
evalExpression { Csaidadc=Constellation_wf4=constellationdiagram(wf("<calc>saidadcc"),5E-8,3.5E-8
evalExpression { Csaida=constellationdiagram(wf("<calc>saida"),5E-8,3.5E-8) }
evalExpression { Csaida1=constellationdiagram(wf("<calc>saida1"),5E-8,3.5E-8) }
it's same of ADS
constellationdiagram(complex(i_data,q_data, T_symbol,delay)
Yes, It's same to ADS envelope analysis
And my problem is that I don't see the dc off-set of second order intermodulation
thank you for  attention
Reply #3 - Jul 23rd, 2008, 4:50pm
What your question or what you want to know is very unclear. This is also true for your first post.
Please explain more clearly.
trumpeu wrote on Jul 23rd, 2008, 8:15am:
First Sorry I wrote wrong in the last post. FUND2=1GHz.
No. If LO frequency(Fund2) is same as RF frequency(Fund1), you must not do two tone envelope analysis.
You have to set netlist like following.
Vol   12 0 RPORT=50 four FUND1 MA (1) 50m 0
Vol1 13 0 Rport=50 four FUND1 MA (1) 50m 90
.modsst 5n 10u
Attached plot is just one. Is this for input(V(11)) or output(V(22)+j*V(31)) ?
I think attached figure is input signal's constellation.
Also you have to resimulate with one tone envelope analysis, and then you have to plot v(11).h(1).
IT's OK
What is OK ?
Explain in detail. There is no output constellation for comparison.
Second order nonlinearity already exists in your Verilog-A code.
Do you mean that there is no change in output constellation(V(22)+j*V(31)) even if you change iip2 value ?
But you don't show any output constellation and your simulation setup is wrong.
I can't understand the above statements.
If you do correct simulation setup where one tone envelope is invoked,
you should plot real(v(11).h(1))+j*imag(v(11).h(1)) for input constellation and real(v(22).h(0))+j*real(v(31).h(0)) for output constellation.
Maybe your problem is that you don't understand general RF simulation technique such as HB and Envelope analysis.
When I have spare time, I will plot constellation of input and output using your Verilog-A code and Agilent ADS later.
« Last Edit: Jul 24th, 2008, 6:14am by pancho_hideboo »
Reply #4 - Jul 24th, 2008, 7:45pm
This is result of ganho_dB=72, iip3_dBm=-10 and iip2_dBm=10.
Reply #5 - Jul 24th, 2008, 7:46pm
This is result of ganho_dB=72, iip3_dBm=-10 and iip2_dBm=-30.
Reply #6 - Jul 24th, 2008, 8:21pm
Different from IM3, there are many types in IM2 definition.
See the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1193566207
For example, self mixing of RF input, Half-IF, proximity of two tones in RF, etc.
Your Verilog-A is not proper for any type of IM2 which causes inband interference.
The following is modified Verilog-A code for RF self mixing or RF two tones in close proximity.
But strictly speaking, this implementation is not so proper, you have to scale and limit IM2 implementation.
Also you can't express Half-IF with this implementation.
Anyway you have to build your own mathematical formulation to model IM2 issue you concern.
"trumpeu_iq_down_mixer.va"
// trumpeu Demodulator IQ
module trumpeu_iq_down_mixer(rf_in, lo_i_in, lo_q_in, if_i_out, if_q_out);
inout rf_in, lo_i_in, lo_q_in;
output if_i_out, if_q_out;
electrical rf_in, lo_i_in, lo_q_in;
electrical if_i_out, if_q_out;
parameter real rin = 50;       //input impedance
parameter real rout= 50;       //output impedance
parameter real ganho_dB = 10;  //Gain in dB
parameter real iip3_dBm = -10; //third order intercept point
parameter real iip2_dBm = 2;   //second order intercept point
real ga, gb, gc, Aiip3, Aiip2, vin, vin2, vout;
analog begin
     ga = pow(10, ganho_dB / 20.0);  //Gain conversion
     Aiip3 = sqrt(pow(10, iip3_dBm / 10.0) * 2 * rout * 0.001);
     gc = (4.0 / 3.0) * ga/(Aiip3*Aiip3);
     Aiip2 = sqrt(pow(10, iip2_dBm / 10.0) * 2 * rout * 0.001);
     gb = ga / Aiip2;
  end // initial_step
  I(rf_in) <+ V(rf_in) / rin;
  I(lo_i_in) <+ V(lo_i_in) / rin;
  I(lo_q_in) <+ V(lo_q_in) / rin;
  vin = V(rf_in);
  vin2 = vin * vin;
  vout = (ga - gc*vin2) * vin;
  V(if_i_out) <+ vout * V(lo_i_in) + gb*vin2;
  V(if_q_out) <+ vout * V(lo_q_in) + gb*vin2;
end // analog
« Last Edit: Jul 25th, 2008, 4:25am by pancho_hideboo »
Reply #7 - Jul 24th, 2008, 8:25pm
The following is Agilent ADS netlist I used.
Hybrid style netlist of Agilent ADS and Cadence Spectre Syntax.
"test_trumpeu_iq_down_mixer.ads"
simulator lang=ads
Options ResourceUsage=yes UseNutmegFormat=no \
TopDesignName="./data/test_trumpeu_iq_down_mixer.ds"
define My_QAM16src( Vout )
  parameters  Carrier_freq=1 GHz  SymbolRate=1 MHz  \
              Pout_dBm=0 _dBm  Rout=50 Ohm
  num_states=16
  Comp_Gain=2
  SF=Comp_Gain/2.236
  UniformDist=_uniform(-0.5, num_states-0.5)
  Vcontrol=_randvar(UniformDist, int(time*SymbolRate))
  V_Source:SRC3  Vstate_in 0 Type="V_DC" Vdc=Vcontrol SaveCurrent=0
  V_Source:SRC4  Vin 0 Type="V_1Tone" V[1]=dbmtov(Pout_dBm, Rout)/2 \
           Freq[1]=Carrier_freq  Vac=polar(1,0) V SaveCurrent=0
  #uselib "sml" , "N_StateMod"
  N_StateMod:MOD1  Vin Vout Vstate_in \
    MaxStates=num_states Fnom=Carrier_freq Rout=Rout \
    StateArray=scalearray( SF, list( \
      1, 3, 2-j, 1-j*2, -j*3, -1-j*2, -2-j, -3, \
      -2+j, -1+j*2, j*3, 1+j*2, 2+j, j, -1, -j) )
end My_QAM16src
simulator lang=spectre
global 0
ahdl_include "./trumpeu_iq_down_mixer.va"
parameters RF_freq=1G
parameters Tsymb=50n
parameters Rsymb=1/Tsymb
parameters Samples_per_Symbol=10
parameters Tstep=Tsymb/Samples_per_Symbol
parameters numSymbols=256
parameters Tstop=numSymbols*Tsymb
parameters ganho_dB=72
parameters iip3_dBm=-10
parameters iip2_dBm=10
I0 (rf_in) My_QAM16src
+  Carrier_freq=RF_freq SymbolRate=Rsymb Pout_dBm=10-ganho_dB Rout=50
I1 (rf_in lo_i_in lo_q_in if_i_out if_q_out) trumpeu_iq_down_mixer
+  iip3_dBm=iip3_dBm  iip2_dBm=iip2_dBm  ganho_dB=ganho_dB
PORT_LO_I (lo_i_in 0) port num=1 r=50 type=sine freq=RF_freq
+ dbm=10 sinephase=0
PORT_LO_Q (lo_q_in 0) port num=2 r=50 type=sine freq=RF_freq
+ dbm=10 sinephase=90
simulator lang=ads
HB:Env1 MaxOrder=4 Freq[1]=RF_freq Order[1]=3 FundOversample=2 \
Restart=no UseGear=no EnvIntegOrder=1 EnvBandwidth=1 \
EnvWarnPoorFit=yes EnvUsePoorFit=yes  StatusLevel=2 \
SweepVar="time" SweepPlan="Env1_stim" OutputPlan="Env1_Output"
SweepPlan: Env1_stim Stop=Tstop Step=Tstep
Tran:Env1_tran HB_Sol=1 SteadyState=1 \
Freq[1]=RF_freq Order[1]=3 StatusLevel=3 \
Component:tahb_Env1 Module="ATAHB" Type="ModelExtractor" \
Tran_Analysis="Env1_tran" HB_Analysis="Env1"
OutputPlan:Env1_Output \
     Type="Output" \
     UseNodeNestLevel=yes \
     NodeNestLevel=0 \
     UseEquationNestLevel=yes \
     EquationNestLevel=0 \
     UseSavedEquationNestLevel=yes \
     SavedEquationNestLevel=0 \
     SavedEquationName[1]="Rsymb" \
     SavedEquationName[2]="Tstep" \
     SavedEquationName[3]="Tstop" \
     SavedEquationName[4]="Tsymb" \
     SavedEquationName[5]="ganho_dB" \
     SavedEquationName[6]="iip2_dBm" \
     SavedEquationName[7]="iip3_dBm"
« Last Edit: Jul 25th, 2008, 12:33am by pancho_hideboo »
