indysjl
Minneapolis
This will vary based on device architecture, e.g. basic structure vs. folded vs. ring, etc.
If you have the device layout, it should be clear how to calculate areas and perimeters.
If you don't have the layout, and the architecture isn't specified, and you are given W/L, just assume rectangular structure (rectangular gates, sources, drains), and the solution is obvious A=W*L (+Sidewall area if not negligible), P=2W+2L.
