Aug 15th, 2024, 3:20pm
how to simulate fully differential amp with switch cap CMFB? (Read 3406 times)
alicia8283
Dec 02nd, 2008, 7:27pm
hi all,
i tried to simulate a fully differential amp which use switch cap as CMFB currently but i face trouble as the CMFB is timing dependant. i tried to connect the test circuit with ideal Balun as describe in "a test bench in differential circuits " which find in this forum but it seems have trouble. How should i test the differential amp with this switch cap?
thanks a lot.
jbdavid
Re: how to simulate fully differential amp with switch cap CMFB?
Reply #1 - Dec 18th, 2008, 8:25pm
I would make a State average model of the switch cap circuit, and use that for the small signal analysies.
jbd
jbdavid
alicia8283
Reply #2 - Dec 18th, 2008, 11:57pm
hi,
thanks a lot for your reply. Could you elaborate further on the method you mention?
Reply #3 - Dec 19th, 2008, 8:23am
He is just suggesting that you replace the SC resistors with real resistors. This of course is approximate. Another approach is to use SpectreRF, as described in http://www.designers-guide.org/Analysis/sc-filters.pdf
alicia8283
Reply #4 - Dec 22nd, 2008, 11:28pm
hi guys,
thanks a lot for the replies. As my company do not have the license for spectreRF  :'( , so i unable to run the way according to the attachment.
Any other method? could you please specify more detail about the approximation method?
Thanks a lot
