Aug 15th, 2024, 5:20pm
How to calculate PS, PD, AS, and AD (Read 1325 times)
nobody
Oct 09th, 2008, 10:32am
Hello, all
I would like to know how to calculate PS, PD, AS, and AD if width, and length are known. Thanks.
AS / AD area of Source/Drain
PS / PD perimeter of Source/Drain
indysjl
Minneapolis
Re: How to calculate PS, PD, AS, and AD
Reply #1 - Oct 9th, 2008, 1:49pm
This will vary based on device architecture, e.g. basic structure vs. folded vs. ring, etc.
If you have the device layout, it should be clear how to calculate areas and perimeters.
If you don't have the layout, and the architecture isn't specified, and you are given W/L, just assume rectangular structure (rectangular gates, sources, drains), and the solution is obvious A=W*L (+Sidewall area if not negligible), P=2W+2L.
View Profile indysjl   IP Logged
Reply #2 - Oct 20th, 2008, 12:56pm
AD is not W * L, since W and L are the *gate* dimensions.  W is pretty close, but you need the diffusion length.  In BSIM4, the model parameters are DMCI and DMCG (Distance from the Middle of the Contact to the Isolation/Gate): AD=AS ~= W * (DMCI + DMCG)
See also this thread: http://www.designers-guide.org/Forum/YaBB.pl?num=1219125207/0#2
indysjl
Minneapolis
Reply #3 - Dec 17th, 2008, 10:05am
Good catch.  Thanks.  A very clear description in the thread.
Are the diffusion length model parameters the same in BSIM3 as BSIM4?
Reply #4 - Dec 17th, 2008, 10:20am
indysjl wrote on Dec 17th, 2008, 10:05am:
No.  BSIM4 has DMCI and DMCG.  I think BSIM3 doesn't have any of this in the original source, but most simulators use the ACM parameter (area calculation method) and HDIF (half the diffusion length).
hzfeiyun
Reply #5 - Dec 24th, 2008, 10:12pm
Geoffrey_Coram wrote on Oct 20th, 2008, 12:56pm:
agree. please check hspice manual and device layout example from FAB.
