Aug 15th, 2024, 7:17pm
How to see the node transient current (Read 629 times)
sch
Dec 30th, 2008, 2:26am
Did anyone know how to see the node transient current in tran simulation  with Spectre.
Rooney
Re: How to see the node transient current
Reply #1 - Dec 30th, 2008, 9:39pm
If you are running with ADE, then go to Outputs --> to be plotted --> select on the schematic. Then bring youe design in the schematic view and click on the node for which you want to see the transient current. You can cross check it the outputs window of your ADE window.
Hope this will work out
Reply #2 - Jan 2nd, 2009, 7:38am
And if running from the command line use the spectre "save" statement (see "spectre -h save" for more details).
