What subversion are you using (icfb -W will tell you)?
There was a case of this happening in early IC5141 versions if you had a Java SDK/JRE in your path before IC - but the wavescan wrappers were adjusted in an ISR to correct for this.
Generally speaking though, I would recommend contacting Cadence Customer Support about this - as there are a bunch of detailed questions that would make sense to try in order to diagnose this.
